Vernier mixture control
Sure.
Transmitted from my FlightPhone on fingers...
I never saw the need for a Vernier mixture control on a carbureted airplane. Especially one a simple as a Cub engine. Are you guys rolling it lean of peak?
My 180 & my last airplane had Vernier mixtures, the one before had the click type.
I liked the click just fine, but since the 180 also has a Vernier prop control the Vernier mixture seems more natural.
In a fixed-pitch-prop airplane, I would probably rather have the click.
No but I do have CHT & EGT instrument. Old cable would vibrate and move over time.
What is on your fancy new cub?
For what it's worth, I have a vernier cable on my throttle, oil flow valve to oil cooler,, and mixture control. Easy make small adjustments with no movements.
Sent from my Pixel 2 using SuperCub.Org mobile app
Here’s an Aircraft Spruce mixture... far more accurate for leaning. Also, not as succeptable for breaking like the wire ones. 98F11A21-EBE6-4CD7-9846-E0916045897D.webp8C0976EF-F279-4FF0-83B5-3C5ED3E6AB2D.webp
...pull mixture cable to full lean position, go in engine compartment and kink mixture cable. Now it will bind in working position ….
I installed a Teflon-lined carb heat cable in my last airplane.
Really smooth operating-- so smooth in fact that it would apply itself on takeoff.
I disconnected it from the airbox, pulled it into the cabin until the wire was showing,
and put a little kink in it. Worked great after that.
For what it's worth, I have a vernier cable on my throttle....
I like a Vernier prop control, am OK with a Vernier mixture control,
but my last airplane had a Vernier throttle and I hated it.
Maybe I'm just uncoordinated, but I found it difficult to make fine power adjustments when landing.
Replaced it after about 2 flights with a standard push/pull throttle.
^^^ Agreed. I'm not a fan of vernier throttles. Push/pull with adjustable friction is much easier to operate. Just don't get it too tight or the throttle will stick. ---That's a joke, remember the old Qantas gripe sheet?
"vernier throttles" easy to take them apart and remove the BB size ball . You end up with a adjustable friction push pull.
I love the vernier Throttle on the Maule You just dial the power down for landing. Perfectly smooth power adjustments.
It is particularly good when contour flying doing surveys, where you can just dial a bit more or less power perfectly smooth where the observer barely ever notices any power changes.
It takes a bit to get used to it. The rest of the time thumb on the button with Index and middle finger forward allow power adjustments just as smooth as any other setup -- And you never have friction to deal with.
If i fly long surveys in the Maule I always miss this set up on the Cessna's afterwards.
There are vernier throttles and then there are vernier throttles. I didn't mind the one in Maules......didn't much care for it, but was relatively easy to use.
The one in my current airplane when I bought it was an accident waiting to happen. Getting a grip on that thing that'd allow free movement without the vernier required unnatural gymnastics. I had it replaced with a standard friction throttle at the last periodic inspection.
Vernier mixtures are highly desireable, however, in my opinion. But, we all know about those......
