TR Dunn
Sharing some results reference my use of NDI, specifically ultrasound, on our PA-18A frame. I recently removed the wings for re-cover, and always desired the L-21 style “glass”, so I decided it’s a good time to pull that trigger while the wings are off. I purchased the Flanagan STC from Cub Crafters and removed the fuselage fabric. External corrosion is easy to locate, my objective of NDI is to locate any internal corrosion in the tubes, again, this is a ‘54 A model that after departing Lockhaven, went to work dusting and spraying and now spends summers on floats. It retains the original top deck hopper frame support tubes with all their original penetrations possibly affording opportunity for liquid intrusion over the decades.
Starting at the rudder post, I took readings at every cluster followed by readings along intermediate tube locations. My objective is to measure enough locations to allow a numerical data driven assessment of the current frame integrity. If a measurement causes suspicion, more invasive testing is warranted, with a final solution of tube R&R. UT is working flawlessly, (see attached photos).
UT is very accurate, however, very time consuming and requires proper technique manipulating the probe to obtain valid results. The ultrasonic thickness tester I am using is a certified and calibrated instrument and I also have oversight by a Level 3 NDI expert who performs/supervises NDI nearly every working day.
I believe the ability to place a number on the actual wall thickness has its merits. UT provides me the confidence of tube integrity very specifically by providing numerical data which meets my objective of verifying the frame structural integrity. When completed, our “A” frame will have a map of tube wall thickness at each tested location, data that I feel is worth my effort.
This process works for me as we already employ UT, as well as other NDI procedures in our shop for corrosion control inspections. Not looking for a debate, just sharing our use of technology which helps us keep these legacy airframes airworthy.
TR
TR
