tedwaltman1
BENEFACTOR
Delta, CO
There have been numerous reports of U.S. Customs staffing issues affecting pilots trying to clear into Alaska.
Ketchikan customs advised one pilot to file eApis at least 3 days in advance!
Northway continues to offer clearance only at 9 am and 3 pm. Here’s what the supervising agent emailed one pilot:
“Northway is a landing rights airport. You must file an EAPIS for Northway and then you will receive a denied landing rights email. This is standard procedure so that all aircraft contact us directly after we have your airplane and personal info in the system. Once the officer has completed what they need to do, they will contact you and make arrangements for processing at Northway at either 9 am or 3 pm daily unless you opt for a bypass to Anchorage.
This can be accomplished IF you can make it to Anchorage with a tech stop only for fuel in Tok.
Northway inspections are completed based on staffing so there is always a chance for delays or unavailability.”
The direct line for Northway is 907-774-2247; Main office is 907-774-2252 or 2242.
Not to confuse things, but the supervisory Custom’s agent in Anchorage said this:
Alcan/Northway has created a work around for the staffing by restricting the hours of aircraft clearing. Anything outside of those hours there has been another work around put in place by requesting bypass and clearing in ANC.”
Northway GA Aviation Airport Fact Sheet: (link here)
Above information has also been posted on http://fly2ak.com
- File eAPIS for Northway
- You will be denied landing rights but now the officers have your contact information.
- When the officers finish what they are required to they will reach out to you, with the contact that was provided through eAPIS.
- From there you have two choices
- Either make arrangement for clearing there at Northway at either 0900 or 1500.
- If those times don’t work for you can ask for a bypass to ANC. If you will need to stop in Tok, AK for fuel make sure that you bring that to the officers’ attention when they contact you via your contact info in eAPIS. If that is the case, then from Tok you will fly directly to ANC for you US Customs inspection and clearance, and then welcome back to the US.
