I am busy with the Trim on my experimental and see there are no part numbers or drawings for the 1/16 trim cables.
Is that because each aircraft is different and need to loop the cable through the pulleys from back to the front, mark then cut to length.
Anyone have any advice on splicing the thin cable.
I gave it a go, but was quiet a challenge to get anything that's worth using.
Thank you,
Neal.
Thank you,
Neal.
