Darrel Starr
Plymouth, MN
I saw in Bill Rusk's Javron thread the tedious effort it takes to get shims in the bearing caps to set tension to limit torque tube movement. It reminded me that I elected not to go through that procedure and just set the bearing drag by tensioning the bolts. The bolts and new stop nuts hold the tension just fine and allow for simple fine adjustments to the bearing clearance as time goes on. I just turned the front bolts about a 20th of a turn to snug them up just right. I cant think of a good reason to fiddle with shims in this application where the relatively giant bolts and nuts carry virtually no load. I wonder if Piper was thinking about engine connecting rod caps when they put shims here. Anyway, 340 hrs later and all is well and convenient for future tweaking. So do others leave the shims out or am I all alone on this one?
