Gordon Misch
MEMBER
Are you coming out to Kirk's fly-in at Booneville in Aug?
Perry, is this a public event? If so, would you have some more info?
No matter how tight I tie down my Cub, I've seen it jump around in big winds due to the flex of the 31" Bushwheels. The tires trump the stretch or no stretch of the ropes/straps. Maybe the rope stretchiness would make more of a difference on planes with little tires.
I never rely solely on the tie down rings as I always take the rope thru it then around the strut then back thru the ring. Would hate to lose a bird with the failure of that little ring.
Also prefer lines with a little give to them for shock absorption, even though they are tied tightly.
I agree regarding knots, from a surgeon's perspective, from a fly fishing perspective and from an aviation perspective.Look at the gear and rope testing done at HowNot2 and you will see that knots are really bad in general for rope such that it will be the rope failing in the knots well before any hardware like carabiners.
Hopefully you are parked into the wind and it is a lifting force. Winds from the side can pick up a wing and drop the other side, Tailwind will pick up untied tail and put a plane on its nose or all the way over.I am just a x-farmer and have never seen a 70-80 mph wind and its effects on a airplane but I would think that especially a cubs landing gear would squash and cause any anchor rope or strap to become slack as the wheels worked outward
There are more than one type of screw in anchors. Some better than others.For tying down, I really like my SlideDown ropes - dead easy to set up, and as strong as the usual knots:
For the ground anchor on grass/dirt, the FlyTies supposedly create a much stronger anchor than the screw-type ones:
Airplane Tie-down innovators - FlyTies®
FlyTies® Company is dedicated to manufacturing the best aircraft tie-down stakes on the market. During the past 20 years we have been able to strengthen and improve our product in order to provide the very best in quality, strength and ease of use.www.flyties.com
Just curious, why the rope and not the strap?Tie down testing:
Just something I found on the internet. I do now use the screw system, and I personally would not use straps. I use rope.
