One thing to consider is how zeroing the thrustline relates to your AOI. On my wide bodied Cub's fuselage, I had the incidence of a stock 12 which is rigged correctly for a negative thrustline. When it was zero'd, the AOI was negative 1 relative to the thrustline. You might say "why would that matter?", and obviously AOA through the airmass doesn't care. But, with a low AOI relative to thrustline, I was "plowing" tail low (presenting a large frontal profile) in level flight and required nose high trim to cruise. That made for a hard working engine and burning a bunch of fuel (ineffecient, obviously). And, the more I tried to climb, the more the airplane was effected. Increase the AOA, the prop would essentially face an inefficiently high attitude to pull the plane. AOA is always going to be exactly how it has to be.... so if your thrustline isn't pulling efficiently, the plane will climb and fly like sh!#. I ended up having Jay make me 1.5" hockey sticks (brackets) to raise my LE 3 dgrees (I have a Javron wing) which put me at positive 2 over thrustline. The fix was instant. Flys like a dream, hands off. Tail is right behind the airplane in cruise (picked up speed at lower RPM, temps decreased, improved handling) and it climbs like it should. Also unexpectedly, I don't even touch the trim any more. I used to have to trim to take off, trim for cruise and trim to land (especially if I wanted to land short). Now, I literally don't touch it. I didn't have to remove the aft wing attachment or de-rig the flaps/ailerons, so besides longer lift struts, getting the wings re-rigged was pretty easy. I did have to shim the top of the fuselage to get the skylight/windshield to match the new wing line, and I made some carbon wing route fairings to blend the LE into the windshield.... don't think the AOI/TL discrepency is a big deal on most 18 fuselages but for a 12, it's a "thing", and I wished I would have known from someone else before having to chase it down. Definitely would be something I'd consider if building. Good luck
