NimpoCub
Nimpo Lake, BC . . . AKA "the Floatplane Capital o
I was readin' in the COPA paper that Canada seems ready to mandate the use of 406 ELTs no matter the cost or hassle factor to us GA types.
Apparently they have not allowed for the lack of similar mandate in the US, and that will make it illegal for US planes without a 406 gizmo to fly across Canuck airspace. Going to Ak? Heh.
How can they be so stupid? Oh yeah, politicians.
This just came in from one of the BC Floatplane directors...
> Transport Canada is drafting a new regulation that requires all aircraft in
> Canada (with some exceptions) to carry a device that will immediately
> upon a
> crash, provide notification of same. This regulation differs from that
> proposed by CARAC and was revised by CARC as the result of lobbying by
> DND
> and NSS. Part of the decision to change the CARAC approved version was
> based
> upon an estimate for supply and install that quoted a value less than
> quoted
> by Gordon. These estimates/quotes still are unconfirmed as only a few
> have
> been installed in GA aircraft and as the new draft regulation has not been
> approved for all of the required installation components. These
> components
> include a remote switch complete with indicating light, possibly an
> annunciator alarm that would alarm when the ELT is activated so that pilots
> would not walk away from an aircraft with a transmitting ELT, possibly a
> re-enforced mounting bracket to better survive a crash and a new antenna.
> This total system may also require an integrity test to confirm that all of
> the system is performing as designed. And, of course, the paperwork
> required
> by TC to install anything new in an aircraft.
> Chuck, in talking to my avionics shop, the price to purchase could be in the
> $1,200.00 range with the installation cost about the same (around
> $1,000.00). Then, the unit requires annual certification which I do not know
> much about.
> As I said above, all aircraft (with some exceptions) will require an
> immediate notification capability for SAR. There is, as far as I know, no
> exemptions to the regulation as is currently possible; ie: do not travel
> beyond 25 miles, placard for when the ELT is out for servicing. So this
> means that no aircraft flying will be without an ELT as there are no other
> forms of immediate notification of a crash currently available.
> Unfortunately all of the current problems with ELT's have not been
> addressed; ie: broken antenna, no G switch activation (all ELT's except
> helicopter ELT models have a 1 directional G switch), aircraft upside down
> or underwater and not allowing the ELT signal to reach the satellite.
> However, false alarms should be eliminated as the digital signal will
> contain the owner's information which will allow the JRCC to contact the
> owner for confirmation (of course, the owner must ensure that he has
> registered the ELT properly and updated this info as necessary). One of the
> benefits of the 406 ELT was that it would have an instant transmit function
> should it be activated during a crash. Unfortunately, the circuitry requires
> approx 20-50 seconds to process its data prior to transmitting the last
> signal.
> The 406 ELT will also include a reduced power output 121.5 signal which
> will
> allow homing of the ELT. The homing of the 406 digital signal will not be
> easy and there are very few cost effective 406 homers on the market. As
> the
> 406 ELT transmits for a half millisecond every 55 seconds, there is no
> continuous signal to home. And of course, 121.5 will no longer be received
> by satellites after Feb 2009. If the new regulation passes, there will be a
> grace period before all aircraft are required to be equipped with a 406 ELT
> as industry could not react fast enough to equip all aircraft in Canada. So
> during this time (possibly 2 years) there will be no 121.5 satellite
> receivers and there will be numerous aircraft still flying with only a 121.5
> MHz ELT on board. During this time, pilots may want to look to other 406
> ELD
> (Emergency Locator Device) that is not automatically activated upon a
> crash;
> SPOT is a good possibility.
*********(snip)****************
Taxation WITH representation ain't so hot either!!
> upon a
> DND
> based
> quoted
> have
> components
> required
> much about.
> signal.
> will
> the
> ELD
> crash;
