Yes and Yes. With AOSS the tires just seem to stick and follow the ground. Bushwheels help smooth out stuff a lot depending on pressure. A lot of it is pilot technique. The old 3 point keep the stick in your gut works but until you slow down some your wings are still creating a lot of lift and allowing the gear tires to bounce, not to mention that tailwheel getting beat up. Keeping the tail up will kill lift from the wings and help load the tires/gear. This helps with the bouncing/braking. Once the firewall go's past vertical now we are in the range that hard braking can induce a prop strike so it is indeed a balancing act. If you are just learning how to fly tailwheel aircraft Bungees are just fine and they will point out bad landings/technique, which is what you want. If the plane is just being built get the AOSS, but if you have bungees use then to improve your skills once you are smooth upgrade when they need to be changed. I will drift to a Pacer story. My first plane was a Pacer, stock gear, big wing, full dash, tired 150 hp, 26 in Good years. I bought it before I had any training and did all my training in it. Most every landing was 2-3 bounces I am sure the boys in the hanger took bets on how long before I bent it. Well after about 150 hours and 800 landings I made myself land on tar whenever possible because it forced me to be good with my feet. Still bounced a bit and worked every landing but it really helped. A bit after that I got some 29 in Bushwheel and MAN was that a game changer! Run them low and I looked smoooooth. One of my friends told me how much better I had gotten. My reply was I still kind of sucked (I could tell from the pilots seat ) but the Bushwheels made up for a lot of mistakes and looked good from the ground. So I guess what I am trying to say is the newer gear/tires will usually make a bad pilot look good. However it will not save a plane from being wrecked by a bad pilot. Learn good pilot skills first, then learn to look good. DENNY
