cubpilot2
SPONSOR
Anchorage Alaska
I'm about finished with all of the repairs / changes to my 18A fuselage and started thinking thru the (what have I forgotten) checklist and the thoughts of "crashworthiness" came to mind.
I have all of the standard stuff with the X bracing, harnesses, seat belt attachment improvements etc. but......
Over the years I've seen many cubs that were involved in relatively minor crashes and have noted that the "front bulkhead assembly" (doorposts forward) is fairly weak, as the lower longerons will often "buckel" upward or fold towards the instrument panel.
One cub that I retrieved experienced this when heavily loaded; lost an engine and was forced down in a pasture. The gear failed (no cables) and when the prop and engine hit they tucked under the boot cowl. The floor boards were buckeled upward to within about 8 inches of the instrument panel. Pilot got out ok but easily could have been trapped. All he got was splinters from the floorboards breaking.
My thoughts are these: Has anyone ever installed an additional diagonal 7/8 in. tube on each side of the bulkhead assembly; routed from the lower front corners and extending to the upper longeron clusters near the panel?
This tube would just clear the "opposite diagonal" tube and should not interfere with any other components (except for perhaps a map pocket)
These tubes would serve as "compression members only" to hold the bulkhead in place in the event of an accident. They would not alter any other structural characteristics of the airframe so they should be "approvable".
What do you think?? Take some shots at it.
