BENEFACTOR
From the STC's I have seen the O-320 STC requires the tubes and the bigger bolts in the cabane V. I have no experience with a gross weight increase STC that ups the gross weight while retaining the O-290-D2.
It has an electrical system. 8.50s.Damn, if your cub does weigh 1017 and is pretty fresh, it’d be a ripper with 160hp. From other posts, I guess a 320 is only 20 or so lbs heavier than a 290? You’d bet that back with a GA Sensenich.
Remind me, are you on 8.00s or 8.50s? Your weight is pretty light with an electrical system and any creature comforts.
I would think so, doesn’t the atlee extended baggage hook onto that 3/8” tube?That looks like a 1/4" bolt in the cabane V, not a 5/16". I would check to verify. Do you have the old battery access cover on the back of the fuselage just aft of the wing root? If so I would look in there and see if there are three 3/8" tubes from the bottom longerons to the top longerons and one between the top longerons. Search this site and there should be pictures.
I actually dont think there is any weight gain from an o290d2 to o320 based on my research I did a while back- or if there was it was negligibleDamn, if your cub does weigh 1017 and is pretty fresh, it’d be a ripper with 160hp. From other posts, I guess a 320 is only 20 or so lbs heavier than a 290? You’d bet that back with a GA Sensenich.
It wasnt calculated. It was scaled. Could you even calculate a rebuild? Seems like that wouldn't work- it was taken down to the frame.If they calculated the weight I would be very suspect because Piper seemed to fib from looking at Super Cubs I have weighed. The O-290 can run a thinner, lighter prop which is a pretty good weight difference but comes with an AD. If you have the 74DM you can use it on the O-320.
As far as the tubes and the Atlee Dodge baggage, trust but verify. I have seen some interesting mods to get the job done. Easy to look and see and also easy to stick a wrench on the cabane V bolts. Sorry but I have worked on way too many airplanes and found way too many discrepancies between paperwork and the airplane.
I believe the left hole is the Cabane V is 5/16 and the gear leg is 3/8 Look at you front gear fitting.The tubes appear to be there and the bolts are there. Am I looking at this right? Why does the drawing say ream to 5/16 but then show 3/8 inch diameter?
View attachment 109339View attachment 109338
How much less? I thought it would be worth more knowing your getting a good crank. I have no reason not to believe its good but you never know.Do you have reason to think it may not be good? Once the engine is taken apart, it's not worth as much as a core.
I agree Kase........ my O-320 has 2300 hrs. A few years ago I bought a -b2b off a Citabria prop strike for a replacement when the time comes. Tore it down and sent all parts to Central Cylinder........then bought 4 new Millenium cylinders.How much less? I thought it would be worth more knowing your getting a good crank. I have no reason not to believe its good but you never know.
You can go .010"I am with Steve on this - send a part out, and it gets machined no matter what. You can only do that twice on a crankshaft.
But doesn’t Airworx have approval to bring a crank back to standard?
That groove is a stress riser which could lead to crankshaft breakage. How would you repair it? Welding and regrinding would create a different stress riser.
Can Airworx just fix the seal groove?
