Daryl Baker
Columbia, Connecticut
Hello Everyone, This is my 1st post. I frequent this web site a lot. Great site. It has given me lots of good info while building this project. Thanks. I thought the people here may want to read about my aircraft. Based at Windham Airport in Connecticut. I did see someone asking about the engine mount length. Aircraft was built by myself over 8 years for approx. $35,000. I have flown it 28 hrs and 20 flights. Is not hard to fly and handles well. Will post some photos. Would be happy to answer any questions.
Summary:
Bush Sport 200 Aircraft Project – N4625D Serial Number 21056
• 37 ft wing span. Dihedral and Washout same as PA18.
• 2 place with large baggage capacity
• Empty weight 1096 lbs. CG 11.25
• Gross Weight 2200 lbs.
• Cruise at 115 mph at 2300 rpm.
• Takeoff rpm approx. 2500-2550
• Takeoff run – Short!
• Climb rate – Excessive!
Construction (From Savaged 1952 PA22 Airframe)
Fuselage:
• Lengthened 2 ft using Javelin Aircraft Company plans. Gas welded.
• Univair STC conventional gear and Scott Tailwheel. 26 inch Goodyear tires.
• Fabricated toe brakes using Univair plans.
• Removed rear passenger door and framed in installing window. Duplicated opposite side.
• Installed Pilot’s side door entry. Duplicated opposite side.
• Installed skylight using plans from an approved FAA Form 337 PA22 installation.
• Installed double jackscrew trim assembly to add structural support strut to the stabilizers. Same basic design as Crosswinds STC Modification.
Wings:
• Assembled from PA22 wing parts and aluminum spar blanks bought from A & E Aircraft Services of Bellevue, WA. Spar blanks are the same dimensions as Piper spars 6061-T6 aluminum.
• Fabricated spars, lift strut fittings, jury strut fittings, leading edge. Front wing spar was reinforced at the lift strut fitting with plans from Javelin Aircraft Company.
• Extra ribs bought from Carlson Aircraft Inc. Piper STC replacement ribs.
• Wing is a close copy of the PA18 wing. Same rib spacing. Wing rib stitched.
• 3 aileron hinges and 3 flap hinges.
• Lift struts were fabricated from Wag Aero Sportsman 2+2 aircraft material kit. TIG welded by a 30 year aircraft welder.
• Micro Air design VG’s on wings and stabilizers.
Control Surfaces:
• Ailerons and Flaps were constructed from PA22 parts (1 and ½ sets spliced together). Ailerons are the same length as the PA18 and the flaps are approx. 6 inches longer (6 ft.).
• The PA22 tail surfaces were enlarged to be approx. the same size as the PA18’s
• 10 inch sections welded in to the center of the stabilizers and elevators. Internal sleeve method.
• The rudder had 4 inches welded in to make it wider (height not changed).
Firewall Forward:
• Engine is from a Mooney, IO360-A3B6D 200HP. Overhauled per the Lycoming engine manual. New D3000 series magneto, fuel pump. Light weight Skytec starter.
• Engine mount fabricated and TIG welded by 30 year aircraft welder. Same basic design as the PA22 Univair 180 HP conversion STC. Same engine offsets as the PA22 mount. Engine mount 10 inches longer than PA22 mount.
• Engine cowling fabricated. Nose bowl purchased.
• Engine baffles fabricated from Van’s RV plans. Oil cooler rear baffle mounted.
• Vetterman crossover exhaust system for Van’s RV aircraft modified with slightly longer tailpipes.
• Prop is a PA-25 McCauley P235 AFA8452 overhauled and re-pitched at 46 (AFA8446).
• Fuel system is similar to the Cessna with both wing tanks feeding at the same time. 36 gal of fuel in two 18 gal wing tanks. Weldon boost pump mounted on firewall.
Summary:
Fuselage:
Wings:
Control Surfaces:
Firewall Forward:
