txfirefighter628
Brownwood, TX
Im looking at buying a PA-12, have one close to me picked out. I've search as much as I could on old threads but still have a few questions.
1.) It has the stock PA-12 gear legs with the flat steel brace. Not sure if SB93(doesnt apply by serial #) or SB97 have been done, will have to look closer when I go look at the plane again. The left gear flat steel has a slight wrinkle/curve in it. Does this toatlly compromise this gear or can it be repaired? If the streamline tubing from SL 109 is added does it make it PA-14 gear?
Piper service letter 113 recommends replacing with PA-14 gear, is the only new PA-14 gear availible the $1300 dollar per side univair gear?
I've read that to convert to PA-18 gear two tabs need to welded on. Can this be done with the fabric on or if some has to be removed is it a easy repair? I plan on repainting the plane in the near future if I get it so a small fabric repair doesnt bother me. To do the 18 gear conversion you need 2 gear legs, the cabane V, 2 weld plates and 2 shock struts, any other parts required?
2.) It has stock fuel tanks with the sight gauge that sticks out of the bottom of the wing. From what I have read from previous post the stock tanks are horribe, guarented to leak and not worth repairing. The easiet replacment I've seen are wag aero tanks but heard they are low quality too, have these tanks improved in quaility at all recently? Do the wag aero tanks have the stock location for the sight gauge or does it have fittings for the dakota cub stlye gauges.
3.) The plane has atlee dodge wing lift struts installed and from the information I've found I belive these struts have a 5 or 7 year inspetion required. Is this correct? Also they have 1" fork fittings, to go to sealed lifetime struts with 5/8" fork fittings does anything on the fuselge or wing have to be repaired/replaced or can the 1" fork fittings be put on the sealed struts?
