Interesting- I don’t think that info was in the manual when I was using the system 6-8 years ago. Haven’t ever heard of sealing with Ekopoly from the outside; would make me nervous about the ekofill adhesion. So I guess you’d seal the areas aft of the tank bay from the outside, and paint the inside when doing the topcoat…? (I agree it’s easy to do and takes no time, just had issues with the unprotected areas aft). Probably best to do the left side of fuselage and belly areas too, since those can get pretty saturated if a plane sits for a few days with an undetected leak…
I never read this either, but it makes total sense to me. As for adhesion, I can't imagine any problem, after all you already have the same products layering in the standard application, they are just in opposite sequence.
Agreed on the left fuselage, that is the only place I've ever had a problem on the 15 y/o finish on my cub. Leaky fuel selector. Peeled at the lower longeron, but I was far more disappointed with the fuel selector r&r than I was with the SS product.
As for vents and drains, I think they're a huge help. I feel like total saturation followed by a quick flash off is far less damaging than a chronic seep. My tank covers do not have the rubber doughnut, and my middle name is not Grace. I have spilled far more fuel
in to my wings than I can remember, and have watched it rain out the back, but it's always dry a few minutes later and have yet to have a blister under the wings. Conversely, on the left fuselage I would have never know there was a leak if the paint didn't blister and peel, yet when I removed the inside panels the inside of the fabric was heavily stained blue. My fuel is typically loaded Rt tank Mo, and Lt tank Av.
All systems have a compromise, you just need to pick which compromise effects you the least and which positive attributes are most desirable to you.
I've been impressed with SS so far. So much so that last year I did a set of AG Cat feathers, as well as the tail of one of my Thrush' That airplane now has two corn run seasons on it and one fall through spring produce season on it. For comparison, prior to this, it was going through legacy systems to the tune of a new cover job every year. I know of no harsher life on a fabric system than this;
A) Caustic chemical baths on every flight
B) Pressure washing to remove said chemicals, and lastly
C) 24/7 outdoor storage in one of the hottest desert climates in the nation.
Take care, Rob
