snowyriver
Alaska
Does anyone have experience with the Stewart System paint? I used their glue and cleaner on my flaperons and liked it a lot. I'm considering using their paint on the plane. Thanks, Craig
upda lk said:I had a very bad experience with their paint.
cgoldy said:...I think that the problem is that when a pro uses it they are loathed to change there old ways. If an amateur uses it they usually stick by the instructions to the letter. I have employed pros and am paying the price. Make them watch the DVD.
1) Don't deviate from the instructions
2) Don't deviate from the instructions
3) Don't deviate from the instructions
"The Eco Prime (one part) is OK but parts would feel tacky after handling a little bit. This was after they had dried for weeks and or months. Seems like the Eco Prime picks up moisture from your hands and softens. It also has a very rough texture like there's grit in it. I filtered it and double filtered it. Tried a lot of different gun settings. It still came out rough. Chemical glues / paint will also make it lift.
I then switched over to their Eco Poxy (two part epoxy) primer and couldn't be happier. It dries hard, sprays out smooth with no "grit" feeling and chemicals will not lift it. "
tamarack said:8. I was holding the gun too far away from the work and causing misting, wasted paint and a dry look. Now I hold it closer -- 5-7" with better results.
Vickie
Roger Peterson said:"The Eco Prime (one part) is OK but parts would feel tacky after handling a little bit. This was after they had dried for weeks and or months. Seems like the Eco Prime picks up moisture from your hands and softens. It also has a very rough texture like there's grit in it. I filtered it and double filtered it. Tried a lot of different gun settings. It still came out rough. Chemical glues / paint will also make it lift.
Do you still prime with Eco Prime before spraying the Eco Poxy.
.... I am experienced in painting cars and other equipment. ......
Has anyone experienced the stewart systems paint peeling off or bubbling up? I have painted my plane now twice and overall the stewart systems paint has not laid down properly. There is another plane at the same airport as me with a similar problem of the paint bubbling. I am experienced in painting cars and other equipment. I don't think this paint has lived up to being user friendly.
