JayH
NE Iowa
Hey folks,
This is going to sound like a really stupid question, but my brain is scrambled right now from too much thinking. For you Smith drivers out there, on the overhead trim crank, when you turn it to the right or clockwise, which way is your yoke traveling, up or down? I know on the side trim, cranking forward is nose down.(yoke traveling up) Transferring that same motion up to overhead, my trim seems backwards.(clockwise, the yoke travels down, which is nose up). I can see where you could reverse this on the side trim coming off the horizontal pulleys, but on the overhead trim system, the only way would be to cross the cable and come off the other side of the jack screw pulley. Mine appears to be correct based on several photos viewed, just seems reversed.
J
J
