Pointeravionics
Breslau Ontario
Hello Everyone!
Just thought we might start a Questions and Answers thread to answer a few questions about our new SkyyHunter 406 ELT.
The following are answers to GPS questions that were raised in a discussion within this forum:
-If there is GPS data available at the time of the crash then that information will be transmitted with the first 406 burst (within 50 seconds). In order to have GPS data available you would have to either have an external GPS antenna (additional cost) for the GPS receiver inside the ELT or feed the data from a NAV interface (not enabled with initial release of units, will be accessible with a firmware upgrade in a future TSO). If you use the internal receiver you will need to supply aircraft power from the power bus via the remote connector.
-The external GPS antenna should be Active with minimum 20 db gain and 5 V, we have researched an economical antenna that meets these specs, AV-GPS by RAMI www.rami.com .
Please feel free to ask questions through this forum or contact us directly at 519.648.3778 or sales@pointeravionics.com
Regards,
Staff at Pointer Avionics
Regards,
