I have a set of PA-18 lift struts, two front and two rear, that are welded shut at the top and bottom. They have the smaller forks. Does sealed mean they are welded shut as these are both top and bottom? When starting to remove one fork, oil seeped out from inside the strut.
I called Univair and they indicated all of their sealed struts have the larger 5/8 inch forks. Did or do, others manufacture sealed struts that would satisfy the strut AD? If yes, how can I tell who manufactured these and if the AD does or does not apply. I am not sure what year these were manufactured or installed on an aircraft, they did come from Alaska however, I have no idea where they originated.
I did a search and found several posts about struts but nothing on how to tell or recognize sealed struts.
Stan
Stan
