Removing Horton STOL for Sportsman?
Buschpilot
Worthington, IN
I am curious about how much work is to swap a 185F from a Horton STOL kit to a Sportsman? It's time to decide on the annual upgrade, and wondering if this is something I should consider, or forget about. I've also struggled to verify if the Garmin GFC 500 STC covers a 185 with the Horton installed, but admittedly haven't worked that hard at it. If you've made the swap, I want to hear how it went!
Probably not worth it. The Sports Man Kit is great , but not worth it if you are already Horton equiped.
Spend the Money on Gas:cool: Cheers...
A bit off-topic, but can anyone provide the stc number for the Owl STOL kit ?
Note- I'm not planning on installing one, just curious as to who owns it now,
so you don't have to bother telling me the sportsman kit is better. :rolleyes:
FWIW I just googled Horton STOL, in case anyone is interested it looks like this outfit owns that stc now:
I did this a couple months ago on a late model 182. Had about a day in removal of the Horton leading edge. About 40% of the rivets were countersunk cherry max and those were a giant PITA!! You could not drive the steel stem out and drill them because the leading edge would just bounce when you hit it with a punch. I took a flap disc wheel and went at the heads of them until they were gone and then punched the tails back into the wing. I would say removal time depends on what it’s got for rivets.
The Sportsman is a great STC, but I personally wouldn't remove the Horton/Owl/Mid-American kit and replace it. James Spikes won at least 8 STOL competitions including multiple times in Valdez with a Horton wing.
Now adding Wing-X... that's a different story!
Just for some balance in this thread...There are many reasons to remove "airworthy mods", however, the most important reason is the owner-operator desires something else. This is what makes capitalism work. What one likes, another does not, and we are fortunate to have choices. I removed an airworthy brand X cuff off my wagon over 20 years ago to install the Sportsman. I did it because that is what I wanted. Is it work? Yes, however, that is a relative term IMO.
The "work" was worth the reward to me and in the end that is all that matters. I would do it again. Your money, your choice.
TR
TR
Absolutely the best response to many questions. Thanks!
I am very practical sometime and forget that a lot of folks (and the gov't.) that own Skywagons have a lot of disposable income. I was speaking from a real world usefulness position only so I'll apologize for not considering that angle.
Here's a cross section pic of the cuffs from Stene Aviation. Click on it to enlarge.
