Heh, heh, heh, this ought to generate more heat this winter than the old corncob stove. Looking forward to much dialogue.
I own and fly a King KY97A, since the night before the narrow frequency change. I fly another very regularly. They've both been absolutely the most reliable avionics ever in my experience. No downtime, no radio-related squawks.
I've flown a few Icoms, with almost identical look and feel ( they actually fit the same tray and pinouts), and a sterling reputation. I actually like the Icom display better: A bit brighter, and if it's mounted low-left (like mine) shows up better; King thought everyone in the world was going to late-model Cessna/Mooney/Piper center stack, fairly high right. Wrong again, especially in Supercubs. If I were to spend my own money again, I'd go with the TSO Icom, but that's just my opinion. The other difference is the Icom gives a positive "chirp" when you toggle active/standby frequencies, which helps you know where you are.
The couple of SL40's I've flown have been great, and I REALLY like the ability to monitor the standby frequecy, but hey, I have 12 presets on the truck radio, and surf them wildly to the great distraction of passengers. I'm a little concerned whether Garmin will keep this one in the lineup longterm. I like the SL40 bright display better than any of the competetive units, too. Especially handy if buried under the panel somewhere, as is typical on 'Cubs. A little more money, but a real contendor for me, especially if AWOS or Center frequencies are used a lot.
I've been around ~15 Beckers in the last five+ years, and actually used a couple. Love the form-factor, but most have had setup problems, or have been back for service. Also some reports of the backup battery corroding over time.
About the same comment for MicroAire, plus the knobs are smaller, the tuning quirks NOT intuitive; still pretty good bang-for-the-buck unless you change frequencies frequently. (And I owned one of these for ~5 years, no trouble, just awkward to tune, especially in turbulence).
Both the Becker and MicroAire are much shorter than the others, so might fit in some panel spots the others might not go. For these 2-1/4" mount applications, you might also talk to Tim Mara at
www.wingsandwheels.com regarding the Dittel line.
The two of the three Valcoms I've flown had the background noise previously alluded to, and revert to a wierd frequency at shutdown, have to be toggled back to where you need to go. Extra, awkward workload. Might be a setup problem, but why bother?
Ignore the rated power, the nominally 4-watt MicorAire has sometimes boomed in better air-to-air, and air-to-ground than the nominally 6-7 watt KY97A, or old 10-watt KX-170B at 100 miles, so that isn't much of a factor.
None of the self-contained intercoms on these radios are very good. Get a decent PS or Sigtronics or the like, with seperate squelch circuits for both mikes.
And make sure the mike gain and sidetone are setup correctly for the headsets you're using: My KY97A has a decent compromise between the Peltor and the Korean Klark Klone I frequently fly with, but some of the others weren't so good. On many you have to pull the radio from the rack and tweak a trimpot near the back, and try again. The Beckers have LOTS of options here, and that's probably where many of the problems lie.
Better to pay attention to who's going to install the darn thing, what their avionics experience is, and make sure you get a good prewired wiring harness, and NEW coax and broadband antenna. And an installation warranty.
At the end of the day, don't go outside what your avionics shop has had good luck with.
As usual, just my limited experience, and worth every cent you paid for it.
Thanks. Cubscout
