Farmboy
SPONSOR
Fort Edward, NY - Fairview, OK
https://www.federalregister.gov/doc...ess-directives-textron-aviation-inc-airplanes
Proposed AD revising existing Textron Aviation Single Engine Mandatory Service Letter SEL-55-01, dated December 7, 2017, and expanding into all models and time.
The FAA proposes to adopt a new airworthiness directive (AD) for all Textron Aviation Inc. (Textron) Models 180, 180A, 180B, 180C, 180D, 180E, 180F, 180G, 180H, 180J, 180K, 182, 182A, 182B, 182C, 182D, 185, 185A, 185B, 185C, 185D, 185E, A185E, and A185F airplanes. This proposed AD was prompted by a report of cracks found in the tailcone and horizontal stabilizer attachment structure. This proposed AD would require inspecting the tailcone and horizontal stabilizer for corrosion and cracks and repairing or replacing damaged parts as necessary. The FAA is proposing this AD to address the unsafe condition on these products.
[h=2]Discussion[/h]The FAA received a report of cracks in the tailcone and horizontal stabilizer attachment structure on a Textron (type certificate previously held by Cessna Aircraft Company) Model 185 airplane. It was observed during maintenance that the horizontal stabilizer tail section moved up and down and had excessive play. After a detailed inspection, the tailcone reinforcement braces were found cracked on both sides of the airplane. Upon further investigation, the FAA discovered similar conditions on 29 additional Textron 180 and 185 series airplanes. The FAA determined that the combination of the attachment structure design and high loads during landing contribute to the development of cracks in the tailcone and horizontal stabilizer attachment structure. This condition, if unaddressed, could result in failure of the horizontal stabilizer to tailcone attachment and lead to tail separation with consequent loss of control of the airplane.
[h=2]Differences Between This Proposed AD and the Service Information[/h]
[FONT=fr2_icons !important][/FONT]
The service information applies to airplanes with more than 3,000 total hours time-in-service or 10 years in service, while this proposed AD would apply regardless of the airplane's time-in-service. This proposed AD would require inspecting for and replacing loose or sheared rivets, which is not specified in the service information.
