WWhunter
Near the Headwaters of the Mighty Mississippi Rive
[FONT=Helvetica, Arial, sans-serif]In a recent conversation with a friend recently about a SC I am looking at the subjects of prop availability was discussed. This particular Super Cub has an O-360-C4P engine. It has all the light weight items (starter/Alt) so the plane is relatively light for an O-360. EW is 1227 LBS.
[/FONT] Being a certified plane I only know of a couple different props that are legal on this engine installed on a Super Cub. A Sensenich and the McCauley, which is what is on the plane (82" climb). Not knowing much about these engines I tried looking up to see if anything else was available but have come up with nothing.
There is a guy at the local airport that has a very similarly built SC and he has a Hartzell Trail Blazer CS prop on his plane. I have found out that the O-360-C4P is a hollow crank engine that does not allows the use of a CS prop.
Is there anyone that knows of any other props that can be used on this engine, legally of course.
