Franky,
Those floats will give you a very hard ride on any water surface other than fairly smooth. The inverted W shape of the bottoms will trap the waves producing high loads on the floats and the airframe. Back during the late 1970s a fellow (Howard Harley) in Florida manufactured and certified some fiberglass floats which he called Fiberfloat. They had an inverted V shaped bottom. They did well in smooth water but pounded so hard in rough water he had to attach shock absorbers to the cross struts to absorb the loads. Even then, he managed to tear apart an airframe from the stresses. He sold a few sets before going out of the float business.
Since you have them, leave them being straight floats rather than throwing more money at them. Use caution in rough water.
Apples to apples...Hi everyone
I just joined this fantastic group, i'm buyin a 1976 Citabria 7 GCBC wich is all apart from my good friend Buzz Cola, the new kid on the bloc below.
I'm planning to rebuilt it in the experimental category, so i will have to modify it enough to fit it in that category, the bird have the wood spars, so this will be the first thing to go, i will rebuilt the wings with a set of spars from Nick Smith (BBI Aviation), the new wings will give me a wing span of 36' 6",
i will increase the flaps lenth and move the ailerons outboard to fit the new wings, thinking about vg's as well, maybe go with the Super Cub ribs to make it a Super Cub wings, it even crossed my mind to put the S Cub ribs on the inboard section of the wing and keep the Citabria ones ont the outboard section but for the moment, it's just an idea, i need to investigate that more seriously.;-)
I also want to get rid of the steel landing gears and come up with a suspension type gears, with shocks hidden in the belly, i've got a few mores ideas but
for the moment, theses are the main modifications that i want to do, i want a good bush plane and be able to go where a Cub will go.
Comments are welcome.
Franky
Yes skywagon8a, i know that, thinking about making a kind composite shoes that will take care of that, or simply make a new bottom, on the other hand, they will probably to get on the step faster, can't win everywhere.
Actually ANY work done on a major assembly from a prior certified aircraft is Part 43 Maintenance and can not be counted. That includes modification and assembly of components. So if using a fuselage frame from a prior certified aircraft all the work that it takes to complete the Fuselage (control system installation of electrical system, seats, cover . . . for the final aircraft does not count.Javron, Backcountry, Piper, Citabria. An Exp builder doesn't get a fabrication point for any but can get an assembly point for all. And 1 point is all that's at stake. There's a lot more to the 51% than the airframe.
it is clear that can not rebuild a certified
aircraft the way it was and try to register it in the experimental category, that is the reason for the 51% rules
My 7GCBC 1978-87. Scout extended gear (heavy; now light aluminum is available), 80" C/S Hartzell prop, Victor Aviation massaged O-320, light electronics, small battery moved to adjust CG, extended rear baggage (fit 25 2x4's inside cockpit), Scout tail spring, Crosswinds STOL kit, extended wings w/Demer's tips, sealed ailerons, lower flap gap seals removed, 40* flaps, sealed elevators, weight about 1250# (heavy but still had stock interior and seating). T/O 50' longer than PA-18 I trapped with on skis, but flew 40 mph faster.
