Hey all,
I acquired a set of Edo 2000's for my newly flying PA-12 project, they are in good shape so I decided to clean them up and prep them for install early next spring. I had them media blasted with crushed walnut shells and they turned out great, the blasters were able to blast down and leave much of the original zinc chromate looking primer. Some elbow grease and a few hours later they are mostly silver, I figure where the chromate looking stuff wants to stick it won't easily peal in the future either.
From reading a bunch of other threads my next step seems to be etching and alumadyning them, shooting some primer and float lacquer. I've been using the PPG DX 303 and DX 330 with good luck for cleaning and etching. In the past I have used OMNI, 2 part epoxy primer on the main plane metal parts with good luck. I'm hoping for one last blast of warm air here next week for the painting.
So my questions:
Do floats take any special kind of primer under the float lacquer? I've ordered lacquer and thinner from Spruce.
And while I'm at it,
Is one type of pump out plug better than any other, I'm thinking of the $3 kind.
What length of float pump is recommended: 15, 24 or 36".
So my questions:
