cubdrvr
SPONSOR
YesCan you print it?
Yes, no problem.Can you print it?
is there a pdf on supercub.orgDrift on over to the J3 Cub forum. They posted a pdf for me, which I stored and printed.
Did you ever get anyone to verify what the reference number is?Is the reference number the same as the file code on the approval document?
The reference number is the number FAA assigned to the AMOC and is just below the address on the letter from the FAA that approved the AMOC. They also stamped my request letter with an FAA approved stamp. I think that also has the reference number written in with a signature from the FAA engineer that approved it.Did you ever get anyone to verify what the reference number is?
Looks like 10 years for my C90 powered J-3.
Yes, also in the stamp block on the original application letter.
I bought a bottle and have it in Madison, WI. You are welcome to some of it.Steve, Where can I obtain an eyedropper of 70% nitric acid?
Cranman
Nope.^^^^Did they ask for the boiled linseed oil elixir process?
67 percent https://www.walmart.com/ip/JSP-NITR...?wmlspartner=wlpa&selectedSellerId=5633&gQT=1I understand the Wal Mart product is .5% I don"t know if that is strong enough for the test.
Jeff, where did you obtain the 70%? Unfortunately I am in South Florida so it makes no sense to ship it back and forth. I do appreciate the offer.
Jon
Not sure why they required others to use .049” especially when looking at the specs between 3/4”x .035” and 1025 7/8” x .035.In 2021 I did a full restoration of my 180 hp cub. A friend of mine was one of the first to have a rudder failure while on floats and his account of what it was like to control the airplane and to land safely was frightening to say the least. It was something that I never want to experience.
At that time there was no FAA guidance as to how to correct the problem. It was obvious that a reinforcement was needed now.
Since the rudder was stripped down for fabric and after cleaning and inspecting for corrosion I reinforced the upper post area. This was done by inserting / driving a lubricated 26 inch piece of 3/4 x .035, 4130 in from the top of the rudder post. This required separating from the 3/8 tube and heating the post to reshape to accept the insert. The tube was rosetted into place and then shaped at the upper end to the original spec and incorporated it into the weld. (no upper post on this rudder). Documented the reinforcement on a 337.
My view was that the combination of the two tubes with a combined .060 wall thickness was at least equal to or greater in bending resistance (in the critical area) than a single 7/8 x .035, 4130 tube used in a new replacement rudder.
I submitted all of this history / drawings etc. to the FAA through the AMOC process and I have received AMOC approval allowing the rudder to remain in service as is.
Happy Days
Not sure either.Not sure why they required others to use .049” especially when looking at the specs between 3/4”x .035” and 1025 7/8” x .035.
