BENEFACTOR
Well as of midnight tonight despite the efforts of a lot of people here at SuperCub.org, ShortWingPipers.org, AOPA, EAA and the Short Wing Piper Club the FAA decided to issue an Airworthiness Directive against all of our aircraft's rudders. I can tell you that no one is happy about it but it is what it is. You can read the entire document here.
https://public-inspection.federalregister.gov/2025-02528.pdf
Here is the compliance schedule:
Category I Airplanes:
Airplanes having both
a rudder post mounted beacon light and a
150 or greater horsepower (hp) engine
installed.
Compliance Time:
Within 2 years after the effective date of
this AD.
Category II Airplanes: Airplanes having
either a rudder post mounted beacon light or
a 150 or greater hp engine installed.
Compliance Time:
Within 3 years after the effective date of
this AD.
Category III Airplanes: All airplanes not in Category I or Category II that do not have a rudder
post mounted beacon light and have an engine less than 150 hp and greater than 100 hp installed.
Compliance Time:
Within 5 years after the effective date of
this AD.
Category IV Airplanes: All airplanes not in Category I, II, or III that do not have a rudder post
mounted beacon light and have an engine of 100 hp or below installed.
Compliance Time:
Within 10 years after the effective date of
this AD.
A little insight into the availability, Univair has a few in stock as does Dakota Cub, Alaska Gear Company has 9 in stock as of 2 pm CST 2-13-25. The issue is that the vendor that made the tail nav light bracket for Univair suddenly announced they would no longer make the brackets. I had a call from Jim Dyer the president of Univair a few months ago about this issue. As of our conversation today a new vendor has been procured and they are expecting a batch of brackets at the end of this month. The issue is that not only does Univair use these brackets but so does Dakota Cub. Alaska Gear Company has started making their own brackets. I guess the good thing is that the compliance time has been spread out so there is hopefully not a mad rush on rudders.
From Piper Service Bulletin SB 1379B
The affected aircraft will fall into one of the following categories:
• For aircraft with an airworthiness certificate issued prior to June 3rd, 1974, these aircraft were delivered from the factory with a rudder post made from 1025 steel. If a complete service history exists and it can be confirmed that the original rudder is still installed, proceed to Part II.
• For aircraft with an airworthiness certificate issued on or after June 3rd, 1974, these aircraft were delivered from the factory equipped with a rudder post made from either 1025 steel or 4130N steel. At owner/operator discretion, proceed to Part I. Otherwise, proceed to Part II.
• Aircraft equipped with a rudder of unknown or incomplete service history may have a rudder post made from either 1025 steel or 4130N steel. For these aircraft, the type of steel alloy used in the manufacture of the rudder post cannot be determined by visual inspection. At owner/operator discretion, proceed to Part I. Otherwise, proceed to Part II.
Also, all PMA'd rudders have been made from 4130 so if your rudder has been replaced with a new one it should be 4130.
installed.
Compliance Time:
this AD.
Compliance Time:
this AD.
Compliance Time:
this AD.
Compliance Time:
this AD.
