Pawnee tach cable
Anchorage, AK
One of our Pawnee’s was written up for a squealing tach cable. I am going to pull the rather long inner cable. What’s everyone’s favorite recipe for lube?
If it was up to me I would put in an electronic tach and be done with it.
Charlie, yup, by the time you buy a couple of those 12' cables, plus the downtime you can pay for an ECI digital tach. And a REAL PITA and time sink to pull all those side panels and stuff for access. As a bonus, much more accurate resolution, so easy to tell if you're down 20 rpm. With the long cable mechanical tach, it's trying to average the oscillation.
Saw you had a nice flight in the ASW-20 the other day. 8)
Thanks. cubscout
Thanks. cubscout
Yep I am getting my ASW-20 dialed in. I really like it!
Electronics International R-1 tach. Power, ground, left/right mag signal. Mag signal wires connect at the key switch along with the P-leads. It even comes with a cap to coverup the tach drive on the accessory case.
