Helmetfire
Caldwell, Texas
I'm starting this thread because I am starting a electrical panel relocation/new instrument panel project on my '54 Supercub, and will have a bunch of stupid questions for you all in the near future. Any help is greatly appreciated! Of course I am working under the supervision of my IA, but I like to consult with the pros here to be armed with the appropriate info when needed. The big chunk of this work will be included in a field approval (hopefully), and our PMI will be visiting tomorrow, so my IA and I will get a chance to talk with him about the approval.
The panel I'm taking out was installed some time ago, is homemade from army surplus tank armor, and over the years has accumulated too many instruments and holes. I'm taking out the vacuum system, moving the electrical panel from the wing root to the lower panel, nixing the stock speaker, installing an Atlee underseat battery mod, and installing a B&C 40A Alt in place of the existing 20A Gen...these are the brunt of the project. The new panel will be a blank from Atlee made from .050.
The picture is what the panel looked like up until a few days ago. The layout will be basically the same with the radio and xpdr moved up and together to make room for the switches on the lower left, and CB's on the lower right. Planning on keeping all but the vacuum instruments with the posssible exception of the VSI...I like the VSI and use it alot but this one has the worst fading, reads about 200FPM low, and I could always have the VS on as one of the functions of the map display on my 396. I will try to move the Mixture, Primer and Cabin Vent controls back close to their original locations keeping the primer close to the start switch as some here have suggested. My GPS has since been moved just to the right of the compass but I'm thinking about buying a small panel mounted compass and sticking it somewhere on the panel, then moving the GPS front and center betweeen the V brace, then hardwiring a cord with a CB that turns on with the radio master.
Old Electrical panel: quite a birds nest behind there, sorry forgot to take a picture of the back...
As far as the wiring goes, my goal is to reduce complexity anywhere possible. I want to incorporate circuit breaker switches where possible to eliminate unnecessary CB's and wiring. Using all new Tyco switches and breakers to keep all the dimensions consistent behind the panel. Heres some general questions I have:
1. I haven't received the B&C 40A Alt yet, what size switches/breakers will I need with that setup? Is the overvoltage control incoporated into the LR3 regulator that comes with the package?
2. Having trouble figuring out what size Switch breaker to order for the LANDING/TAXI LIGHTS. Mine are tied together somewhere in the wing and both turn on with one switch. Presently they are protected by a 30A CB, but I think that might be a little high. I calulate two 30W / 12.8V bulbs will draw roughly 11-12 Amps, but my computation could be wrong.
3. Take a look at my rough wiring diagram and let me know if this would be an appropriate way to wire the system. I'm still a little fuzzy on the symbology especially in the master switch area (DPST switch), the two solenoids by the battery, and where the regulator ties into the system. My main concern is the items located on the 12V bus, is this close to how it should look? Hopefully its clear enough to read. (look familiar Steve?)
To clarify the items a bit starting from the to of the 12V bus:
Field CB 5A
Ammeter
Aux pwr CB 5A
Ldg Lights CB Switch 20A?
Nav lights 5A?
Strobe 5A?
Cabin lights 5A? (Grimes instrument map lights left and right)
Avionics bus:
Com 5A
XPDR 3A
Encoder 2A
T/B 5A
GPS 5A
Starter 5A
thanks for any help!
Aaron
Field CB 5A
Ammeter
Aux pwr CB 5A
Nav lights 5A?
Strobe 5A?
Avionics bus:
Com 5A
XPDR 3A
Encoder 2A
T/B 5A
GPS 5A
Starter 5A
Aaron
