Staff member
Northwest Arkansas
So below is our 1955 C-180 panel. It's hard to think about changing it because it was completely redone for me by the late Paul Fisher eight or ten years ago, but there are lots of things that need to be addressed and so I am looking for advice on this VERY slippery slope.
Important things to bear in mind:
1. This is our "Cirrus". It's our traveling plane. We like that we can land it off airport and here and there, but we have another plane for kind of monkey business also.
2. I use it as an instrument flying platform - it has an STEC 30 autopilot (also installed by Paul Fisher) - and I am perfectly comfortable with flying it IMC as it sits.
3. On top of the panel, you see the Stratux raspberry PI ADSB receiver. Obviously, to comply with 2020 I am going to have to do some kind of ADSB upgrade at some point.
4. I'm perfectly happy with things like Foreflight / Garmin 496, etc, helping get the job done that I don't need an Aspen.
Things that are not working:
1. The EI UBG is on the fritz
2. The tach is on the fritz
3. The clock is on the fritz
Things I am considering:
1. Remove all of the EI instruments and install a CGR-30 OR an EDM-900 - interested in pros and cons. I can convert eight instrument into one!
2. Move the dang GNS430 to the top of the panel so you don't have to apologize for grabbing the passengers knees every time you put in a new destination (this is tricky in '55 I believe).
3. Put in something like that new whizbang garmin G5 display
4. You can't see the KX-155 because the yoke is blocking it, but replace it with something else.
5. Replace the ancient audio panel above the 155 & the intercom with a PS engineering audio panel
5. Get rid of the marker beacon lights
I would like to spend as little as possible on all of this - like $10,000 or less.... but maybe I dream....
Ok there you have it, fire away!
