porti
Smithers B.C Canada
It seems that spring is in the air early this year in the North West and I have been getting an urge lately to refesh the look of my 1947 Edo's... The floats are in good shape after a recent repair under the left step...they are amazingly quite water tight... The old dull, water stained gray paint looks tired.. The paint is not flaking off however and I have been contemplating not trying to remove the old paint but instead just give them a very good sanding with some wet /dry and spray on some new gray??? what do you think??
My other alternative; I have industrial sandblasting equipment as well as lots of experience blasting and painting HEAVY EQUIPMENT... I have no experience with "soda or potassium"as a media for blasting. I do know however that aluminum does not fair well under a blast from regular abrasive.. Does anyone here have any experiance with blasting aluminum floats...
Since I'am on a roll I will take this opportunity to ask a few more float questions.. I have purchased new O rings, pump out funnels and plugs from Lake and Air... I do not like the looks of the clear inspection covers and was wondering if there was another source for reasonably priced aluminum inspection covers.. Also after painting the floats I would like to apply a different product along the tops between the two rails to help protect the tops and inspection covers as well as make this area less slippery. any suggestions?? maybe a similar material to what they spray in pick up boxes.
One last question and then I will stop.. I have seen a few float planes here in Norther B.C. with the underside of their floats covered with a black paint like substance... I asked one guy if he thought it made a differance in his float performance and he said that it did...I dont think that this is for helping with leaks, seems like extra weight for nothing but I am new to this any comments would be appreciated and I thank you in advance
porti
porti
