I'm installing rudder cable fairleads back through the frame. Due to the frame being wider the rear rudder pedals are further outboard from centerline compared to a stock PA18. I have a string pulled from the rear rudder pedal through the pulley underneath the rear seat through the remaining fairleads. Everything looks good until you exit the cable/ string to the rudder horn. When it exits to the rudder horn the string is pressing against the rear fairlead. Just wondering if anyone has any pointers, is this normal, its within 3* , just don't like it rubbing.
