PA14 Installation of Federal A2500A Skis
PA14driver
Port Alberni, B.C.
I just acquired a set of Federal A2500A skis to install on my PA14. From my research on this site, a number of members thought they were a good ski. They are 14" wide by 70" long. I see they are not on the type certificate, rather A2000A are. Does anyone have a 337 to install the 2500's? They do not have teflon on the bottoms - should I put that on now, or just replace the steel runner with teflon?
I can't help you w/ a 337 or field approval process for the skis, but can vouch for the Federal 2,500's being an excellent ski.
There isn't many PA-14's in the world, and there isn't many of the old original Federal 2,500's still around either...probably more skis than -14's though. That said, I can't imagine you having much/any problem making the skis "legal" for the -14.
You really do need to put UHMW (plastic) on the entire ski bottoms, not only does it GREATLY reduce damage & wear on the aluminum ski, it makes then slippery so thye can do thier job better. Throw the steel skeg away, down the center...don't need it, and don't want it.
Keep in mind that the federal skis have a parabolic rake and convex bottoms; "bannana" shaped front-to-back, and side-side. Take your time putting the UHMW on, you'll need to get creative clamping the plastic in place and make sure everything fits nicely before securing them permantly w/ counter sunk screws with nylocks on top. A lot of guys are running the bottom plastic out a couple of inches to gain some surface area....I make mine about 4-5" overall wider than the ski bottom. Easiest was to start the fitting process is to bend the edges of the plastic in a brake so you'll have a nice radius on the outside edges where the plastic sticks out...keeps from having other probelms if/when you slide sideways on glare ice in the wind.
Several ways to make a nice skeg system, on way is to use a sacrifical bolt head. As you lay out a pattern for the plastic, make one hole large to accept the skeg-bolt. Best place to put this skeg in directly inline with the axle, on the inside edge of the ski. Use washer to shim the bolt down far ebough to where it will make contact when you're on glare ice. Every so often as the "skeg" [bolt head] wears out replace it.
To prevent water from getting inside the tunnel (which frezzes, gets heavy & can break the tunnel), from the bottom when you're in the water (OVERFLOW), you need to make SURE the tunnel is sealed well before putting on the plastic. You can weld the original holes closed from the old metal skeg. Use some "5200" marine sealant around the base of the tunnels, boottom of tunnel to bottom skin, when everything is clean and preped well...then paint the skis w/ "silver" float paint.
Federal A2500A Ski Installation on PA14
Thanks for your feedback Luke. The plastic UHMW bottoms will certainly extend the life and reduce the friction. I'll check out how much weight/ft2 that adds for the 3/16" material, although everything is a compromise. Each main ski, as they sit now, c/w rigging, weighs 36.25 lbs. The tailski fully rigged weighs 6.25 lbs. As you point out getting the UHMW to conform to the shape of the ski bottoms will have its challenges, and I gather that is where the technique has its part to play.
I have a set of these skis. They were originally for a L-19 or Cessna 180. Keep in mind that there is a right and a left to these things. Level the tops and the take a squint down the length and you will see what I mean. I like them because the towers. are as tall as a set of gar-areo 8.50-10s. I buy a compound from some air-boaters that is a two part 3-m product that glazes as it sets up. It will wear off but you just paint more on. I've asked them what it was but they wouldn't say, They sell it for bottom protection to skid over gravel and get a pretty good price for it.
Jay, I have started to do some Internet surfing on protective coatings that provide abrasion resistance and slip effectiveness, given the simplicity of painting on a product. Under the web site www.belzona.com there is a product Belzona 1341 that appears to meet those qualifications. I have no idea as to the cost, or application specifics, but no doubt there are similar products out there, comparable to what you are using.
I will try to contact the people that I got the coating from and try to get more information. I haven't used these ski's in a while. I have them loaned out and they will probably need some re-coating when I get them back. It might be a couple of days before I know. The coatings you found look really interesting.
