In accordance with Type Certificate No. 1A2, 209(b), when 89-2000 EDO floats are attached to a PA-18 they must be installed I/A/W EDO drawing 1490 or 69470. (anyone know if there are other changes to the aircraft noted in these drawings other than the landing gear change?) Below that statement are additional limitations for PA-18S-125's and 135's. The document then references to Section IV for models PA-18S-150 and PA-18AS-150. As most PA-18 do not have data tags that have 18S, is this section legally applicable to a straight PA-18? I believe, technically, changing the landing gear does not change the model, that would require a change to the Airwortiness Certificate. Also, Section 401(q) and (r) describes the required "Interior Equipment" for "landplanes' and "seaplanes". Your PA-18-150 with 2000 floats attached is now definitely a seaplane, has it somehow changed to a PA-18S-150? Does the PA-18S-150 Flight Manual now become required equipment? Should the limitations (airspeed) listed in the PA-18S-150 Flight Manual now become the required markings in your PA-18-150?
