I've made a few posts previously gathering opinions and such on this project. I have finally had an opportunity to transport all the pieces and such to my shop and have begun the inventory process. It appears I will definitely have more questions than answers.
It looks like the project started life as a 1951 L-21A with an O-290D. Records indicate that the engine was converted to an o-320 in '79. The engine log also indicates that the engine has undergone transformation up to a -C2B. The O-320 parts manual I have doesn't even mention C2B anywhere. So question 1..... Where can I find updated info on O-320 models and their specifics.
The wings appear to be 13 rib wings with fuel tanks in both wings. The left was wing was damaged hence why I believe this project even exists. The most recent project owner began to rebuild the left wing but time and interests changed. I have seen 13 rib wings mentioned in various posts and will research shortly. Question 2...All of the drawings in the Northland files show 15 rib wings...... Thoughts/concerns..???
The fuse has all the indications of a fairly decent 70 year old tube and fabric fuselage. No major corrosion and one section of lower left longeron has been replaced. Just forward of the instrument panel appears to be the plate where the data plate WOULD be attached. Either A it was painted over a couple times or B it doesn't exist, but I haven't seen an actual serial number for the fuse. I don't have an Airframe log but the engine log does have references to the N number it was installed in. It is highly possible when the aircraft was damaged it damaged the fuselage and the fuse I have is a donor from???? The fuse I have is a D window fuse whereas I believe an L-21A fuse should have the square "military" windows. Feel free to jump in here.
Looking forward to all the input I receive. Project should be fun.
-MB
-MB
