Here's an amended comment to the STC PDF
STC- FAA APPROVALS for AIRCRAFT NOT ON THE FAA AML listing or otherwise
MODIFIED by FAA APPROVED ENGINE CHANGES
Installation of the Lightweight alternator in vintage aircraft is APPROVED for aircraft OTHER
THAN those listed on the FAA AML by specific language in the STC SA02283AK cover sheet:
How that works:
STC certification is obtained to a set of standards related to the STC application. An approved
model list is then issued by the FAA which designates those KNOWN type certificated airplanes
for which the STC is an applicable installation.
In the case of many older airplanes, engines like the A-65 or C-75 Continental have been
replaced with upgraded versions like the C-75-12, C-85-12, C-90-12 or -14, O-200, the O-300,
or the GO-300. Each of those improved engines can be FAA approved for installation on
certain airframes by either FAA field approvals, FAA STCs, or FAA approved service letters
that modify the type design criteria- any of which can be cited by the mechanic as “FAA
APPROVED DATA” substantiating the change on an FAA form 337.
It is not possible to list on the FAA approved STC AML, a comprehensive listing ALL of those
potential combinations, since many are one-off change approvals, or otherwise obscure FAA
approved data that is not readily available to the FAA engineering personnel or the STC
holder/applicant.
Since MANY older airplanes have been modified with engine changes, where the installed
engine CAN NOW ACCOMMODATE AN ALTERNATOR, because the engine has a suitable
generator drive pad drive, the FAA has addressed such changes with a general approval in the
limitations and conditions of the STC itself. The Alternator STC SA02283AK has such a
condition and FAA approval at paragraph 5 of the cover sheet.
It states:
5) This installation approval is limited to aircraft models equipped with
a Continental C-75-12, -12F, -12FJ; C-85-12, -12F, -12FJ, -14F; C-90
-12, -14F; C-145-2, -2H; O200-A, -B, -C, O300-A, -B, -C, or GO-300-
A, -B, -C, -D, -E engine in accordance with FAA approved data.
This set of FAA ‘open approval’ instructions in the STC were developed with the FAA’s full
understanding and knowledge that such vintage airplanes often swapped engines for
performance and availability reasons.
This FAA APPROVAL CONDITION was intentionally added to address the inherently
restrictive nature of an AML, and to provide greater options to the end users and operators who
wish to incorporate a modern, lightweight electrical generating system into their vintage airplane
which has already adopted other upgrades or safety enhancements.
The installation of electrical busses, and other wiring in the airplane may of course be approved
pursuant to original factory TC data, by FAA field approvals, or simply by a reference to the
acceptable data in sections and paragraphs within AC43.13-1B & 2A, on the FAA form 337
