Crash
GONE WEST
Nikiski Alaska
As most of the guys know, I have been building up a 180hp PA-18 for the last year and I finally got it signed back into service and put 4 hours on it today. I've been asked to report my impressions of the conversion and parts used. First here is the list of parts used, starting from the spinner and working back
1. New Univair 180 hp spinner assembly.
2. New Penn Yan nose bowl
3. New Cub Crafters PMA?d stainless steel cowl channels (all four)
4. New top cowl and fasteners
5. New Penn Yan bottom cowl.
6. New side cowls with original Piper latches.
7. Factory new Lycoming O-360-A4P engine
8. New Penn Yan O-360 conversion dynafocal engine mount w/ new lord rubbers, bolts and hardware.
9. New Penn Yan carberator heat box.
10. New B&C L-40 light weight alternator w/ LR-3 solid state regulator.
11. New rear mount light weight oil cooler supplied with Penn Yan conversion.
12. New engine baffling.
13. New Airframes Inc exhaust stacks with slip joints built in.
14. New Atlee Dodge exhaust muffler.
15. New Atlee Dodge muffler heat shroud.
16. All new scat hoses.
17. All new carburetor heat, cabin heat, windshield defrost, rear seat heat and mixture push pull cables and knobs.
18. New Atlee Dodge PA-18 boot cowl attached with 6x32 nut plates in cowl channel and ss screws..
19. New false boot cowl attached with 6x32 nut plates in cowl channel and ss screws
20. New instrument panel with electrical switches and wiring moved from wing root panel to instrument panel (approved 337).
21. New Potter Blomfield breaker switches for landing lights, nav. lights, radios, alternator field, and alternator.
22. New pop out breakers for low voltage and starter.
23. New keyed mag. switch.
24. New TSO?d tachometer.
25. New AMP guage.
26. New TSO?d Becker Transceiver.
27. New Garmin 196 GPS mounted in panel.
28. New PS Engineering PS-3000 stereo intercom with 3 sets of jacks in wing root panel.
29. New intercom and radio wire harness with head phone jacks made up by Chief Aircraft?s certified radio shop.
30. New oil pressure line.
31. New primer lines.
32. All new mil spec. wiring and terminals.
33. New interior panels with gray hammer metal powder coating.
34. New LP plastics windshield.
35. New slider window tracks.
36. All new side plexi glass and sky light.
37. New Fine Line pilot and passenger seat cushions.
38. New ¼? Birch plywood floor boards with Poly Fiber 2 part epoxy varnish finish.
39. Brake master cylinders reconditioned.
40. Brake calipers honed and piston O rings replaced.
41. New brake pads installed on both calipers.
42. New left and right Dakota Cub PMA?d PA-18 wing assemblies with 24 gallon tanks and tank lids installed. PN 14394 (L.H.) and 14394-1 (R.H.). (replaced modified Piper wings with droop tips, not wrecked)
43. New Dakota Cub PMA?d standard PA-18 flaps. PN 12768 (L.H.) and 12768-1 (R.H.)
44. New Dakota Cub PMA?d standard PA-18 ailerons. PN 42585 (L.H.) and 42585-1 (R.H.).
45. New Univair wing tip nav. light mounts (left and right).
46. New landing lights and landing light lens (LP Plastics).
47. New Wag Aero certified pilot and passanger seat belts with pilot?s shoulder harness.
48. New Univair PA-18 fuel selector and all new fuel lines installed per Cub Crafters headerless fuel tank STC.
49. New Atlee Dodge pressure fuel tank caps.
50. New Steve?s Aircraft gascolator (STC?d).
51. New heat ducting for rear seat heat and defrosters.
52. New Airframes Inc. PA-18 fuselage. SN AF18060
53. New Airframes Inc. PA-18 left and right elevators PN AF12770
54. New Airframes Inc. PA-18 left and right stabilizers PN AF12769
55. New Airframes Inc. PA-18 rudder PN AF40622
56. New Airframes Inc. PA-18 fin PN AF40592
57. New Airframes Inc. PA-18 lower door PN AF12257
58. New Airframes Inc. PA-18 upper door PN AF12256
59. New Airframes Inc. PA-18 left and right 3? extended heavy duty landing gear legs.
60. New Airframes Inc. PA-18 extended landing gear short legs.
61. New Atlee Dodge 3? extended landing gear safety cables.
62. New hydrasorb bungees (one 1280 CW and one 1380 CW per side)
63. New Airframes Inc. H.D. rear lift struts.
64. All jury struts and clamps powder coated.
65. New Univair front rudder pedals.
66. Sticks, stick stubs, torque tube, rudder pedals, brake pedals, and all clamps were powder coated.
67. All new Univair control pulleys.
68. All new galvanized 7x19 1/8? mil spec control cables with thimbles and sleeves.
69. New trim cable.
70. New Univair forward trim pulley and pulley shaft.
71. New Univair trim crank handle.
72. All new trim pulleys.
73. New trim balance springs.
74. New Univair H.D. trim screw.
75. New Univair trim screw yoke.
76. New Scott 3200 tail wheel assembly.
77. New Scott tail wheel spring kit.
78. All new mil spec screws, bolts, nuts and misc. hardware used throughout.
79. Ceconite 101 with Superflight STC for Dacproof, Sprayfill, the butyrate
The first thing I noticed is it accelerates from a dead stop much harder then the O-320-160 it had in it before. It really sets you back in the seat and you had better have it lined up down the runway before throwing the whip to it. When it breaks ground even with one notch of flaps it climbs out like a rocket. I keep pushing the nose down, but if you just leave it alone it will run up to about 75 mph and set in at a 1500 fpm climb out. After flying a 160hp Cub for 12 years it just amazes me and I find myself grinning as it goes up like an elevator. The Airframes Inc fuselage and Dakota Cub wings must be as close to perfect as you can get. Right out of the gate it flys flat and level, hands free. It also trims out and holds altitude very well.
Before this rebuild it had extended wings, flaps and ailerons. I noticed it has much lighter stick input with the stock ailerons and feels good with full flaps. I can't say I found any of the "nose heavy" feeling others said the 180hp Cubs have. One thing I like is when landing you just pull on full flaps and 45 mph with no trim adjustment and it floats in nice and easy. Before with the O-320 I was always cranking the trim handle while setting up to land and it was a distraction.
Cruise is around 101 to 105mph at 2400 - 2450 rpm. I can tell that an O-360 shakes more then an O-320 but the dynafocal mount makes it run like a sewing machine. It is the smoothest Cub I've ever been in.
In conclusion, it is hard to beat a nice light 160hp Cub, but this 180hp Cub really rips and I like that. I would have a hard time going back. Crash
25. New AMP guage.
69. New trim cable.
