pelican-12
Montreal,canada
goodmorning everyones !!
is there any of you operate a -12 with 0-320 kenmore stc and happy of the result?
i am asking myself if its worth it i fly 90% of the time alone with no heavy loads ,my plane is a straight 0-235-c1 weight 966 pounds with the goodyears 26" bush wheel ,will it be a drastic change to compare the ias ,rate of climb ,and take off? with that stc can i use a borer prop on the 0-320 ? or i need an other stc for the prop ,will it worth all the change ,i was interessted in that stc because you dont need to change all the front end ,engine mount,muffler,and cowling and the price is cheap. i have a borer prop 82x42 in hand almost new (400 hrs) what i need is a 0-320 conical mount . i herd about nose heavy , can i correct that by moving the battery ferther back to correct it ? all answer will be listen good or bad :roll:
thank you
pelican-12
i leave in quebec, canada i dont know if there is any difference compare paperwork
thank you
pelican-12
