One of the most fun things I have learned to do on my build is press forming (aileron/flap parts). 100 dollar Harbor Freight 20 ton press, 90$ Harbor freight air over hydrolic ram, chunk of horse stall mat and your in business. Great fun!! I cast aluminum dies for mine but I also found for a few items a piece of press board works as long as you place a stiff piece of metal between it and the ram. Good pictures Mike!
Thanks, Algonquin. Being Canadian, things will cost a bit more here, but this gives me a starting point. I don't want to take the fuse apart until I'm as sure as I can be that I can afford to put it back together!
The original question ask what will all of this weigh, I knew I had weighed my new univair fuselage but for the life of me I couldn't find where I put the note. Found it today on my bulletin board-who would have thought to look there, comparing the weight of my new fuselage to the old it was 12# heavier-using a certified bathroom scale. Mods include: gross weight increase, weld on float fittings, overhead 'X' brace, pa-14 cathedral; 1" seaplane tube on left side; rear fuselage square bracing. that was before paint
