oldbaldguy
I bought my first long wing Piper last summer and have been trying to figure out how to land the thing consistently ever since. Mine is a pretty much stock PA-12. As far as I can tell it flies like it's supposed to -- sort of truck like, but is great for cruising around with my arm hanging out the window. This is an honorable thing and I do it a lot. But my landings often suck. I learned to fly taildraggers in a 100 hp Taylorcraft, then owned a Champ and a Flybaby. I've also flown Citabrias and such quite a bit. Never had a problem until now. I've made just about every kind of landing imaginable in the 12 so far: good ones, bad ones, curvy ones, hard ones, bouncy ones, etc. Some have been downright scary. I cross the fence at 65 or 70 indicated then bleed off speed until the wheels chirp (I'm on concrete most of the time), then I'm all the way back on the stick, etc. Don't how fast I'm going at this point because I'm looking outside. Sometimes the 12 agrees, sometimes it doesn't. I convinced myself recently that I'm landing too fast and went out and tried some at slower approach speeds and ended up with a higher rate of decent than I'd like. These landings were firm, but short and no worse than many of my others. I've landed on grass only once and it was a real greaser after floating for a bit. All my other taildraggers seemed to go out of their way to tell me how they wanted to land -- each one had a sweet spot I could feel when all the stars lined up. My 12 lacks this feature and does pretty much whatever I tell it to whether it's right or wrong then laughs at me when I screw it up. Anybody out there have any suggestions/ideas/magic formulae?
