PA-12 Brake cylinder mounting.
guanaco
Can anyone please post a picture of the brake cylinder mounting on the floor board? Rebuilding my PA-12. The parts manual shows a flange over top of the cylinder leg-inboard side.
Yes it does help, thank you. I noticed the tab on top of the cylinder leg that holds it down is missing in the picture.
Yes I see what you mean! I’ll check when I’m out at the airfield next, I don’t remember if it’s got just 2 or 4 bolts per cylinder, but there certainly aren’t bolt holes in the floor to fit those tabs
I’ve looked again and found more photos, there’s actually a 3rd bolt through the same leg hole which your photo and the parts catalogue shows the tab to be :) and it’s in the same relative orientation on both sides. So no tab, but a bolt :)
