Hello! We are currently working on a project to finish putting together a PA-12 that was untouched in storage for a couple of years. I do not know the full details, but this is an aircraft that was worked on at another location. So far, it has been pretty straightforward. However, we've run into a bit of a hitch with the battery location. The original battery box has been provided, and the intent is to use it. However, the cables for the battery have been routed into the Aux Luggage Compartment. To clarify, it is not the underside, but straight into the Luggage Compartment, through the AFT wall of the compartment. There is no structure or brackets inside of this compartment that would indicate a place for a battery or battery box to sit, and the floor panels for the Luggage Compartment do not show any openings or hardware attachment point either. Looking through the documents that came over with the aircraft, we have not come across any STC or 337 that provides a clue for the battery location or why the cables were routed as such.
Has anyone on this forum come across this before? Or perhaps know of an STC that applies to this change in battery location? I have included these two pictures for referance.
