CDraper-SDAirService
Rutland
SD Air Service, Is Currently rebuilding a PA-12 crash (floats) the craft already has a 160hp but we will need a new prop etc. the fuselage is completely torn down and one wing is trash and struts should be inspected, The aircraft already has flaps and extended gear. Basically wondering what we should recommend to the owner(who happens to be a very close friend). What mods, STCs. Tips? Owner has kicked around the idea of dual doors, but wants to make a "Bush Machine". Extended Baggage ? Baggage Doors? Bigger Flaps? This will be a certified aircraft.Wing Mods?
***The Aircrafts Floats were destroyed by the prop and were bent in half from the impact, the floats rigging tore into the floats and we responded to the crash with about 1/3 of each float to spare. the fuselage had about 25 bends and the aircraft did in fact spread about 3/8" we used a rope affair to pull it back together. the tail did droop aswell but we jacked it out. The craft has a boxed tail x brace ceiling and the cathedral. Already has super cub trim and controls, *Had a borer Prop.... Also how can I get more info on the long flaps and squared tips?***
-CDraper
-CDraper
