PA-11 Windshield on J-3 Boot Cowl
Stinson Pilot
North Bend, Wa
Will the PA-11 windshield work with a J-3 Boot Cowl?
This is for my Wag PA-11 CWC project. It has a J3 boot cowl and no forward fuel tank.
I know the regular PA-11 and up cowls are wider.
I did numerous searches, lots of info on the difference in the windshields, but I couldn't find an answer for this question.
Just want to be sure before I order the windshield.
Thanks...
I doubt it. The PA-11 slants at a lesser angle as I recall, and the width is definitely different. Why not use the J-3 windshield?
No. Only a J-3 windshield will work with a J-3 boot cowl.
BTW, a PA-11 windshield is not wider than a J-3"s. A Continental powered J-3 and the PA-11 are built on the same Type Certificate [A-691]. There are differences between a J-3 and a PA-11 fuselage but width is not one of them.
The J-3 boot cowl has to accommodate a 12 gallon fuel tank and is several inches taller than that of a PA-11. The PA-11 windshield is raked back more than a J-3 windshield and provides less drag. The channel on the boot cowl for the bottom of the windshield is further forward than that of a J-3's. A J-3 bottom windshield channel is shaped differently because the boot cowls are different shapes.
I have a j3 with a lot of supercub mods. It stil had the j3 firewall and pa-11 windshield. Looks like they trimmed it short. It wouldn’t fit on the 11 boot cowl, it was too short. The j3 boot cowl didn’t have a hole for the fuel tank and the -11 windshield came almost to the firewall.
Sounds good. A fair bit of trimming I assume. Most of the “open cowl” PA-18/180 banner planes used PA-18-95 boot cowls because the lower portion was a couple of inches narrower than the 150 boot cowl, and the windshield slanted like the PA-11. This reduced vibration in the tail exacerbated by the open cowls.
For whatever it’s worth I completed a Wag plans sport trainer a couple years back. I used a stock L-4 fuselage, a Wag Aero J-3 boot(without the gas tank hole) and a PA-11 windscreen. It fit fine. Never looked back. Bottom of the windscreen is only an inch or so aft of the top cowl.
Hope this helps.
Sarpy Sam
Stinson Pilot, If you follow Sarpy"s advice you will be disappointed in the results.
