Does anyone know of an STC for Cleveland 6" wheels and single puck brakes?
How about weld in shoulder harness brackets for the 11? I swear I saw them somewhere in all my digging and now I can’t find them.
I’ve seen those, but they’re all bolt in. I swear I’d seen some weld in brackets recently but I can’t find them.Don't need an STC for those although I think Atlee has one. Wag Aero, Univair, and Atlee dodge offer shoulder harness mounts and belts.
Which begs the question: Does the FAA’s “more relaxed” view of methods to install better restraints suggest that welding tabs to fuselage tubes would be considered a “minor alteration”? They’ll now permit “non tso’d” belts, soooo? MTV
Tony Clyde makes a nice set of shoulder harness brackets for the front and back.
Thanks, I remember that now.
Ordered the STC from Atlee for the PA18 trim system today.
Ordered the PA18 seat belt STC from Univair today and they said my false spars should be ready by the end of the week.
I also go the CD from the feds today. This airplane has been in Colorado for most of it's life. It flew 2200 hrs between 1948 and 1955. It flew another 800ish by 1983-85 and has been in pieces ever since. It was also based in Glenwood Springs (5916' MSL) for quite a while with the original 65hp engine. I can't imagine it set the world on fire coming out of there. Its pretty cool to think about this old bird passing through the old Stapleton Airport too.
From memory I recall early J3s having the folded seam steel compression struts later replaced by aluminum square tubes.The strut next to the aux tank is steel but all the others are aluminum. Anyone know anything about this? I'm thinking about replacing it with an aluminum one just for the weight savings. Ounces make pounds!
Got that field approved many years ago on a couple but doubt I could pull that off these days.I'm not sure if it was brought up but since everything is apart it's a worthwhile mod to change the spar and top deck to a PA-18 style. It definitely is a bit of a hassle doing all the welding and getting it right but the visibility is worth it.
Good work on the rebuild so far! Keep the updates coming
Make sure any wiring is installed BEFORE the fabric goes on!
Buy new gear legs, after all your work you'll sleep better
Looks like you have been putting Walt to work
