TR Dunn
MEMBER
In reality the truss design was in use long before flight. It was merely adopted into the realm of flight due to its strength to weight ratio. By "design" I infer engineered the truss type of construction for the required forces. If you believe Piper merely riveted some pieces together and hoped for the best, you are misinformed. These ribs are indeed engineered, in the sense that, do I dare say it, math was employed to meet a strength criterion. The topic is TRUSS construction, I have referenced no other design. However, since you opened the door, one can easily engineer a truss rib stronger than your referenced "stamped out aluminum rib", if strength were the only design criterion. TRPiper didn't design the truss rib, truss ribs have been around since the early days of flight but they were made of 1/4" wooden sticks. Piper just shorten the amount of time to build one out of wood and glue by riveting aluminum together. Granted the aluminum truss rib is stronger then the fragile wooden stick built ribs but no where as strong as a press stamped out aluminum rib
