Lots of factors in the weather that catch my attention. Seeing sleet and freezing rain in a report out there in February really makes makes me uncomfortable.Oh, man, this one gives me the willies. Reminds me of flying Shelikof Strait in my younger years….i was fortunate.
Prayers for all involved
That looks suspiciously like a flat spin. No skidding to a stop...one wing broken back and the other broken forward. Fuselage squashed flat. Iced up? Stall & spin...loaded at, near, or aft of the rear CG limit? Ice on the wings and/or tail will effect the stall/spin characteristics which were not flight tested. Yes if it had deicing equipment and approval for flight in certain icing conditions, it was flight tested. Ice forms in various shapes and sizes...all can not be tested. Not pointing fingers, just my observation from the available information. I've seen innocuous ice formations do unexpected things to an airplane in flight.
Fed Ex lost a Caravan 10 or 15 years back down in Wyo to ice. I’ve been told that ice builds on the tires (and gear) and the wheels roll fwd and rebuilds. Never ending scenario. One more nail in the coffin(s). RIP.That looks suspiciously like a flat spin. No skidding to a stop...one wing broken back and the other broken forward. Fuselage squashed flat. Iced up? Stall & spin...loaded at, near, or aft of the rear CG limit? Ice on the wings and/or tail will effect the stall/spin characteristics which were not flight tested. Yes if it had deicing equipment and approval for flight in certain icing conditions, it was flight tested. Ice forms in various shapes and sizes...all can not be tested. Not pointing fingers, just my observation from the available information. I've seen innocuous ice formations do unexpected things to an airplane in flight.
Gary, are these Caravans equipped with boots or TKS?Here's the preliminary track log for the Bering Caravan. ATC would have been in contact until some point. Icing was lurking nearby: https://www.flightaware.com/live/flight/BRG445/history/20250206/2340Z/PAUN/PAOM/tracklog
The anti-ice TKS needs fluid to function, and fluid needs to be available. Here's an early version (and maybe non-current) of Cessna's Supplement 1 to the POH/AFM. Note the limitations and configuration for flight into icing conditions: https://www.martinaire.com/wp-content/uploads/2021/06/Revision-10-Icing-Supplement-1.pdf
The glass suite (typically Garmin 1000 series) has a flight parameter memory, as does the PT6-*** - "FAST" or Flight Data Acquisition, Storage and Transmission. It can provide prior operational data via download after flight.
Now to line up the holes in the cheese.
Bering's are TKS Mike, and the larger PT6 ~800hp+ engines with 4-blade props. They have Northland maintain them at some level so they appear and disappear periodically. Top notch operator with common equipment and avionics suite.Gary, are these Caravans equipped with boots or TKS?
I hate it when the NTSB uses adjectives in lieu of facts. In the report they claim the base of the beacon had a “significant” amount of ice on it. The accompanying picture showed ice, maybe less than an inch thick. In my experience flying Caravans this is not a significant amount.Bering Air C-208 Preliminary Report 3/19/25 from the earlier fatal accident 2/6/25. Now it's national news and Congress is having hearings next week relative to recent events.
The report is preliminary and subject to change. The weather near Nome was reported as >light icing conditions. Airspeed deteriorated below recommended. It initially appears the plane was over gross and fat on fuel for the last leg back to Nome. In the future having a dispatch service available like Part 121 to assist a Part 135 pilot might help with some of the work load. Sad deal for all.I hate it when the NTSB uses adjectives in lieu of facts. In the report they claim the base of the beacon had a “significant” amount of ice on it. The accompanying picture showed ice, maybe less than an inch thick. In my experience flying Caravans this is not a significant amount.
If the final report determines that the plane was brought down by icing I won’t be surprised, so my objection to the use of “significant” is probably pointless in this case. Still, I wish the NTSB would stick to facts and omit adjectives that are subject to interpretation.
Yes, the PT6-114 P&Ws in an early Caravan burn around 400pph. The Caravan that crashed had a different engine with a higher fuel burn.800 pounds of fuel is two hours? (guessing here). Wonder if that was part of the pilot's bad weather 'just in case'.
Rare than having extra fuel in bad weather is a bad thing.
Gary, I’m guessing you’ve got access to an AFM. Does it mention a minimum airspeed in icing conditions? My recollection is 135 KIAS, but it’s been years since I flew a Caravan.^^^^Yes Pete that's what it appears. The GARMIN G1000 suite knows the flight parameters and can record same. ATC "suggested" he slow his approach as they cleaned the LZ in Nome. Maintaining airspeed is critical in icing conditions according to Cessna's Supplement 1 in the FM. The apparent initial finding that power was increased, perhaps in response to deteriorating airspeed, and the autopilot disconnected, was similar to a prior event here in Fairbanks for another Caravan that encountered SLD-induced heavy icing and lost control, but eventually recovered.
There's lots of responsibility and potentially heavy task saturation placed on single pilot ops in those aircraft. Nobody wants to pay for a 2nd PM.
Look at post 3878 in this string....Gary posted the AFM Supplement for ice.Gary, I’m guessing you’ve got access to an AFM. Does it mention a minimum airspeed in icing conditions? My recollection is 135 KIAS, but it’s been years since I flew a Caravan.
