37 mile long lake....wind right down the lake too. Wonder what happened here. Glad no one was seriously hurt.
You may have answered your own question. Even a Beaver has limits in the wave action it can handle.
That’s been a common area for cracks for a long time- please note nowhere have I seen any official link to any recent crashes related to these cracks, in spite of whatever online conjecture may be going on...
Heard today that the Carbon Cub raffled off in Alaska recently was damaged at Hot Springs, Montana. Prop strike and wing damage. My info is third hand, so someone else may know a lot more about this incident.
I believe the otter that crashed right after take off in Dry Bay early this summer was an elevator issue.
Not sure if it was the same failure, but hey- if a spar is failing it seems prudent to have it fixed. If it is a common issue, and some mechanics just blow it off 'until we have time' to fix it, :evil::evil::evil:as a pilot I would prefer an emergency AD.
Had enough of 'leave it for now' attitudes.
Not only the increase in horsepower but also the change from a slow turning radial engine to a high rpm turbine. The vibrations generated by the two engines are vastly different which creates a totally different fatigue pattern with different types of failures. Over long periods of time new stuff happens which would not have happened had the engine not been changed......with 150+% hp that they were designed with, and treat them accordingly. ...
Did you get your PM?This exact subject has been discussed a lot by mechanics and owners up here.
And just to add to the mix, the garret’s turn the opposite way; always wondered if/how that affected things on an airframe that was used to something else for the first 20k hrs. Have seen some crazy cracking on the stabilizer skins- had one with 3-4 cracks that showed up in 200-300 hours. Scab patched in the middle of the season, then the patches cracked almost right away. Reskinning with thicker material and fixing some cracked ribs put a stop to it. Also have seen some serious wing strut cracks, one had a strut that would vibrate so bad on takeoff, you couldn’t see the middle of it...This exact subject has been discussed a lot by mechanics and owners up here.
You should witness a flutter analysis test when it is done in the hangar. The plane is placed on jacks and a vibration making device is attached. When different frequencies are introduced the airframe bends and twist like a bowl of jelly. I guarantee that if any of us ever saw the airplane wiggle like that in flight you would need more than a clean pair of shorts. These test are a safe way to determine what the safe dive speed may be without an inflight flutter test program. The test of a popular light twin I watched was done because they were getting different flutter speeds between different versions of the same airplane in flight. It was discovered that the presence of a large oxygen bottle fixed behind the baggage compartment was the culprit. Now who would have guessed that?And just to add to the mix, the garret’s turn the opposite way; always wondered if/how that affected things on an airframe that was used to something else for the first 20k hrs. Have seen some crazy cracking on the stabilizer skins- had one with 3-4 cracks that showed up in 200-300 hours. Scab patched in the middle of the season, then the patches cracked almost right away. Reskinning with thicker material and fixing some cracked ribs put a stop to it. Also have seen some serious wing strut cracks, one had a strut that would vibrate so bad on takeoff, you couldn’t see the middle of it...
I don't recall what the support looked like, only that it was supported. It likely would have jumped off a standard lifting jack. My observation took place in 1966.Probably not the standard aicraft lifting jacks though as these would change the resonant frequencies seen in at least the wing structure. I saw the DC-9 Super 80 (later named the MD-80 series) in ground vibration test in the Douglas flight test hangar. That was many years ago but I think it was supported by a special bungee system attached to the landing gear.
This paper confirms my recollection - https://citeseerx.ist.psu.edu/viewdoc/download?doi=10.1.1.469.9806&rep=rep1&type=pdf
Notice how the stabilizer of the PA-30 is flexing at 20:. That was the issue which was being tested when I witnessed the analysis. Those stabilizers had a tendency to bend up or down at the mid span. This is what determined the Vd speed. Vne = 90% of Vd.We buzzed the Gee Bee Z many years ago, here is part 1 of the youtube vid.
https://www.youtube.com/watch?v=MtiN48ePYwA
That speed was too low for flutter. Perhaps the elevator cables were too loose or something else needed attention? Each version had different flutter speeds. The B model with the back window was different than it's predecessor. Tip tanks, Oxygen systems, deicer boots any combination, all had different speeds where flutter was noticed. In the end Piper reduced the Vne on all of them to the same speed rather than to have a variety of Vnes. The one I was involved in had all the extras. Turbo, deicer boots, prop anti-ice, oxygen tank behind the baggage, Tip tanks, B model windows, in other words it was loaded. Great airplane!I had 2 PA30s and the last one scared me with tail flutters. I use to descend from higher altitudes to approach altitude by putting descent rate at 300fpm until it reached the yellow arc and then it would start to flutter. Did it twice and nothing nothing seemed to fix it. It is now living in Australia.
Jim
Descending from high altitudes is a classic. What was your true airspeed?
What do you consider high altitudes for a PA-30? Also the airplane limits are based upon IAS in this airplane. It does not fly in the altitudes where this would mater to any extent..Descending from high altitudes is a classic. What was your true airspeed?
