It’s remarkable that the failure of such a relatively small piece of metal can exert such enormous force on the controls that very strong men and women can’t overcome its effect.
This type of control problem isn’t all that uncommon, the Twin Bee has a elevator tab that COULD crash the plane if the control rod comes off.
I changed your
will to
could. It has never reached my ears that a Twin Bee did crash due to this issue. Most, if not all of them which are gone are due to pilot errors or mishandling an engine failure (again, pilot error).
It did almost happen when the push rod (Piper PA-23 part) broke. It took two of us holding the controls with all our might in order to attempt to reduce the flutter. It's hard to say at this point in time whether we had much effect. The flutter did not stop until the wheels rolled on the ground. The only thing I can be certain of is, slowing the airplane had the most effect at reducing the flutter forces.
This airplane has a long balance arm with a lead weight on it extending forward of the elevator control horn. Due to a ground flutter analysis test the weight of the lead was increased. The arm was then tested for the increased G loads and found to meet the FAA requirements of +/- 14 g in one direction and +/- 28 g in the other. ( I forget the actual G loads, But they are huge). When we got the airplane back to the hangar we found this arm twisted like a pretzel and rubbing on one of the elevator cables. It came that close to breaking the elevator cable.
Paul, an earlier incident with this same trim tab happened when it set up a high frequency "buzz" While doing a high speed dive test (not yet at the objective speed). This "buzz" transmitted into the push rod which was controlling it. The oscillations of the push rod exceeded the bending strength of the rod while under compression causing it to buckle. During this process the elevator was destroyed. This particular issue was solved by placing the bellcrank on the opposite side of the tab and changing the winding of the trim cable so that the rod "pulled" in this trim condition rather than "pushing".
I don't doubt for a minute that one of the components which ak49flyer described could have failed causing this Otter to crash. Most pilots and mechanics do not realize how critical these trim tab components are. Take this as a heads up from someone who has been there more than once ..... and survived.
I know of one other example in which this same thing happened (tab push rod separated) on short final to landing with a Fairchild FH-227 at PWM. The pilots had their hands full, but also were successful in landing.
