skywagon8a
MEMBER
SE Mass MA6
There are special flatter ground drill bits for drilling titanium. With the correct drill bit, it is not difficult.
i find drilling titanium easier than stainless.
Harder to driil means better heat reflectivity?
it's been a few years ago but i found a scrap sheet of ti on ebay. Was a lot cheaper than getting a small amount from a supplier.
Ti is insanely high in price.
Sorry for the delayed response. I REALLY liked the electric trim and am planning to do it again. I have ordered a different motor, not that I disliked the last one, but this one has a lot more torque and spins a little faster. Funny how we always want more. BDPG -38-86-12V-3000-R51 from Anaheim Automation
http://www.anaheimautomation.com/products/brush/dc-gearmotor-item.php?sID=248&pt=i&tID=103&cID=46
I have not used it yet so I can not confirm it but it looks good on paper. See the thread on "Building a Smith Cub" to get all the info from the last electric trim install with motor specifics etc
Hope this helps
Make sure you seal that flange well, or tuck it behind the firewall at the bottom like Piper did. Otherwise, any oil that may get on the firewall will find its way to the inside of the bootcowl.The titanium firewall turned out to be easy to work with. A fly-cutter worked perfectly for bigger holes. A 4 pounds more weight saving from the old stainless steel one.
For less then 200$ with the flange, it makes a really nice piece.
Now I need to proove to Transport Canada: ''the firewall will will not suffer damage sufficient to endanger the aeroplane if a portion of the engine side of the firewall is subjected to a flame temperature of not less than 2000° F for 15 minutes. "
I guess that with more than 3000 F melting point for the titanium 6-4, it is more then enough.
looks good are those Cloude G's rib's and spar?
