I don’t know, I didn’t torque it.
Try a lower lip such as this, on this Backcountry Cub. You could attach it to the grey portion of your lower cowl...So it seems that the difference in pressure from upper to lower isn't enough. What are some ways to increase airflow? Sea plane lip is one I've heard recommended, any other ways? Here is a pic or two of my lower cowling area.
Sorry for the fuzzy pic, what else would you check?
Thanks.
Also, how large an opening do you have on your side cowls when they are closed. It should be 2-1/2" to 3" measured at the mid widest point.
Then you need enough lip to create a horizontal "shadow" over your lower cowl exit hole that extends back past where your lower cowl exit hole ends.
(you’re calibrated to “ of water correct?)
CamTom, can you explain, not sure what your saying.
Here’s a not-so-great pictorial example:
If you were to shine a light from directly in front of the plane, my new lip (outlines in red) would create a shadow that extends past the opening in my lower cowl exit (also outlined in red... maybe I should have used different colors, haha).
It made a pretty big difference in my lower cowling pressure as compared to static pressure.
Wes is there a through opening around the air filter element to the rear cowl exit? It would seem that blocking that passage just behind the air filter (or?) might lower the air pressure below the engine. Adding ram air to that area might be raising it is my assumption. Didn't Piper seal that passage?
Gary, Piper did seal that space. I left it off in my Cub just to see what happens and never found a need to put it in as the temperatures all were within my limits. While I can not verify my theory, it appears that maybe the excess ram air which bypasses the round intake filter is actually accelerating the out flowing air thus helping with the cooling. Sort of acting similar to an exhaust augmenter tube?Wes is there a through opening around the air filter element to the rear cowl exit? It would seem that blocking that passage just behind the air filter (or?) might lower the air pressure below the engine. Adding ram air to that area might be raising it is my assumption. Didn't Piper seal that passage?
It's a bit shy of 2.5-3.0 inches,
Augmenter tubes require a whole different design process. There are specific diameter, length, position of the exhaust exit in relation to the entrance to the augmenter, etc....He has two exhaust stacks around which augmenter tubes could be built as another experiment.
